NO ONE WANTS TO LOOK OLDER THAN HIS OR HER AGE
Page 1 of 1 • Share •
Many people who begin to use better edible oils are amazed at the difference in their skin. They find that their skin feels creamy, supple, soft, and lovely to the touch. Hard skin, greasy pores, zits, bumps and acne disappear. These are the most obvious changes that many people notice on using good oils along with balanced nutrition. They also get an enhanced feeling of well-being.
Aging
No one wants to look older than his or her age. But if your skin is full of premature sags and wrinkles, you cannot avoid it. You may not think of your skin as an organ. It is actually the largest organ in your body. Your skin has an extremely critical role to play as it has to provide a barrier against a very hostile environment that includes bacteria, fungi, and perpetual oxidation caused by the sun. furthermore, aging is an important factor in the appearance of autoimmune disease. The immune system may be suppressed or weakened as a result of factors such as over indulging of alcohol, caffeine, tobacco, drugs, sugars and of course poor diet and lack of sleep.
Your skins visual appearance gives you a window in to the internal state of your body. As you know when you look good, it is usually when you are feeling strong and health. When your skin has a rosy glow, this means that you’ve got good blood circulation within the skin and probably through the rest of your body. On the one hand, you often know you are getting sick when you see pallor to your skin, indicative of poor blood flow. You can bet that the rest of your body is not to far behind.
One unmistakable sign of aging is the formation of wrinkles. Scientifically speaking, wrinkles are caused by the cross-linking of collagen fibers in the skin, and the cross-linking can be accelerated by inflammation caused by the constant exposure to the sun. The most effective way to reduce wrinkle formation (other that staying completely out of the sun) is to reduce Arachidonic acid (omega 6) levels in the skin, thus decreasing the potential for the production of pro-inflammatory “bad” eicosanoids (PGE2 series).
An even more powerful approach to preventing wrinkles is to increase the levels of ‘good’ eicosanoids (PGE3 series) by increasing your intake of Omega 3 fatty acids. Due to their powerful anti-inflammatory actions, these good eicosanoids will do far more to reduce the inflammatory process that leads to wrinkles, than all the fruit acids and vitamin E creams you can possible rub on your skin. This is because ‘good’ eicosanoids are both very powerful vasodilators which increase blood flow to make your skin healthier. Increased blood therefore increases your production of the key structural proteins of the skin-collagen and elastin as you age. These structural proteins give your skin it’s firmness and elasticity. As the production of collagen and elastin decreases with aging, you skin starts to droop and sag. In order to keep collagen and elastin at increasing levels, you need to increase the blood flow to your skin, since that stimulates the enzymes that produce these structural proteins. With improved blood flow and decreased inflammation, you skin will look years younger.
Aging
Peter Mwaura Mutiti:
Mobile: +254-723-024-871
http://petermwaura.active.ws
E-mail: petermwaura@active.ws
pmmutiti- Forum Director
Number of posts: 103
Kenya: Nairobi
http://taslykenya.blogspot.com: http://petermwaura.active.ws
Peter Mwaura Mutiti: Teaching old blood cells new tricks
When you hear someone mention circulation you probably think of the heart and major arteries—and for good reason. Circulatory disorders such as hypertension (high blood pressure) and atherosclerosis (hardening of the arteries) are major risk factors for heart disease, heart attacks, and stroke. But there’s more to it than that. With all the attention on the heart and arteries, it’s easy to overlook serious health problems affecting the smallest components of the circulatory system—microscopic blood vessels called microcapillaries, where the critical exchange of oxygen and nutrients actually takes place. If blood isn’t flowing through this web properly, it can trigger all sorts of health problems, many of which may not seem related to circulation at all.
A number of factors contribute to poor circulation as we age. Arteries and veins become stiff and congested as cholesterol and calcium plaques accumulate and restrict blood flow. Spasms in the smooth muscles surrounding the circulatory arteries and veins can also choke off circulation. These same processes also occur in our microcapillaries, reducing microcirculation and impairing the critical exchange of nutrients and gases in tissues and major organs.
This problem only gets worse as we get older because of changes in the composition and structure of blood cells. As you reach middle age, the blood starts to thicken and congeal as platelets and blood proteins make cells sticky. Plus, the spleen—the organ that removes old, damaged blood cells from circulation—begins to slow down with age, which means new, healthy blood cells are replaced at a sharply reduced rate. And to make matters even worse, as blood cells age, they become stiff and no longer appear round and evenly shaped. This makes it harder for them to pass smoothly through the capillaries. In fact, the angular, jagged shape of the old cells can damage the fragile microcapillaries even further.
Eventually, these age-related changes take their toll on the microcapillaries, reducing circulation to the tissues and blocking the flow of nutrients and oxygen. Removal of carbon dioxide and other metabolic waste products is also hindered. This leads to a slow buildup of metabolic garbage that can gradually bury the cells in their own waste products. In time, the cells, poisoned by their own metabolic byproducts, begin to waste away and ultimately cease to function altogether.
The combined effect of poor circulation and old blood contributes to a host of symptoms, including deep fatigue, fuzzy thinking, frequent infections, and lowered sex drive—all conditions usually considered just “normal parts of aging.” If circulation doesn’t improve, it can lead to more serious conditions, such as high blood pressure, heart attack, stroke, diabetes, and arthritis. But giving your body a fresh supply of healthy blood may target all of these problems and more.
Ann Njoki: Forum assistant director and Tasly member
Registration date: 2008-01-10
Re: NO ONE WANTS TO LOOK OLDER THAN HIS OR HER AGE
Thank you for signing me up. Am a new distributor in the lowest level, having joined TASLY AFRICA (KENYA) 2 weeks ago, and on slowing aging, what else other than omega 3 do you use to reduce the omega 6 fatty acids?
Thanks again.
Thanks again.
JANE-
Number of posts: 2
Kenya: YES
Peter Mwaura Mutiti: We help our members create health to achieve future with Tasly. Tasly has been a market leader in the modernization and standardization of TCM-Traditional Chinese Medicine.
Ann Njoki: Assistant Forum Administrator
Registration date: 2008-12-03
Good Skin Looks
You can use cardiotonic pill, royal jelly capsules, foot reflexology (use blood & Energy Circulation Foot Massager For at least 15 minutes daily). Remember to drink carmelia tea at least 2 cups daily.
The above prescription works well for your skin.
Peter Mwaura Mutiti
Peter Mwaura Mutiti
Kenya: Nairobi
Permissions of this forum:
